• Hwy83 SUZUKI ONLINE STORE
Drive Train-Chassis Parts
Store/CLICK HERE For Sidekick & Geo Tracker Parts/Drive Train-Chassis Parts
Transmission /Transfer Case - Axles - Drive Shafts - Suspension -Steering Parts
Filters
Clear all
Filters
Clear all
NEW Brass T-case Bushing (Tracker-Sidekick-X90)
$41.99
NEW Clutch Pedal Shaft 89-95
$79.99
Shifter Rebuild Kit (TRACKER/SIDEKICK/X90)
$74.99
NEW Camber Bolts SET OF 2
$29.99
NEW Camber Bolts SET OF #4
$39.99
NEW Shift Lever Spring
$19.99
NEW Lower Shift Lever Boot
$29.99
NEW Bolt Assortment Kit
$29.99
NEW Manual Transmission Dust Shield/Inspection Cover
Out of stock
$44.99
NEW Auto Transmission Dust Shield/Inspection Cover
$54.99
NEW Clutch Cable 1996-98 2D
$84.99
NEW Clutch Cable 1989-95 2D READ DETAILS
$84.99
NEW Clutch Cable Hardware
$34.99
NEW Fuel Level Sending Unit
$49.99
NEW Fuel Pump Assembly 1989-96
$99.99
NEW Brake Bleeder
NEW Brake Bleeder
NEW Brake Bleeder
$9.99
NEW Speedometer Cable 89-98
$69.99
NEW Locking Hub Gaskets
$19.99
Lock Out Hub Bolts
Lock Out Hub Bolts
Lock Out Hub Bolts
$24.99
NEW Wheel Hub-Spindle Lock Washer Screws
$12.99
NEW Magnetic Drain Plug (Read Fitment Details)
$19.99
Front Wheel spindle 4x4 89-98
Out of stock
$129.99
Wheel hub hardware kit
Out of stock
$39.99
NEW Driveshaft Flange
$64.99
Rear axle shaft PASSENGER SIDE 89-95
$174.99
Rear axle shaft DRIVER SIDE 89-95
$174.99
Differential flange
Differential flange
Differential flange
$39.99
Clutch Arm (Trans Side)
$74.99
Auto locking hubs
Auto locking hubs
Auto locking hubs
$174.99
Transfer case mounting bracket
$29.99
Transfer case shift lever
Out of stock
$64.99
5 Speed shift lever
5 Speed shift lever
5 Speed shift lever
$89.99
89-95 Front INNER axle shaft
$84.99
Engine-Transmission Plate
$44.99
Flex Plate (3 speed)
Out of stock
$144.99
Transfer case rear housing
Out of stock
$89.99
T-Case Drive Chain
T-Case Drive Chain
T-Case Drive Chain
$134.99
T-Case Front Output Shaft
$49.99
Alignment Dowels (Engine to Trans)
$34.99
