• Hwy83 SUZUKI ONLINE STORE
Engine + Under Hood Parts
Store/CLICK HERE For Suzuki Samurai Parts/Engine + Under Hood Parts
Parts found under the hood and for the 1.3L engine
Filters
Clear all
Filters
Clear all
NEW *BLACK* Coolant Hose Kit (Samurai)
$84.99
NEW Speedometer cable (Samurai)
$49.99
NEW Heater Control Valve
$109.99
NEW 8V Rocker Shaft Screws
$24.99
NEW Distributor (1986-89 Samurai)
$134.99
NEW Distributor Cap
NEW Distributor Cap
NEW Distributor Cap
$29.99
NEW Distributor O-Ring
$10.99
NEW Samurai Throttle Cable
Out of stock
$49.99
NEW Starter Bolts
NEW Starter Bolts
NEW Starter Bolts
$17.99
NEW Engine Air Filter
$29.99
NEW PCV Valve
NEW PCV Valve
NEW PCV Valve
$19.99
NEW Hood Prop Rod
NEW Hood Prop Rod
NEW Hood Prop Rod
$65.99
1.3L Distributor Housing + NEW O-ring
Out of stock
$79.99
NEW 1.3L Timing Cover
$84.99
NEW Washer Tank
NEW Washer Tank
NEW Washer Tank
$39.99
NEW Washer Tank Pump
$24.99
NEW Coolant Tank
NEW Coolant Tank
NEW Coolant Tank
$34.99
Intake Boot (1.3L Carb Engine)
Out of stock
$79.99
Metal Carb Hat (Works with Toyota 3K swap)
Out of stock
$79.99
86-89 Air Cleaner Box
Out of stock
$124.99
NEW Warm Air Tube (air box to exhaust)
$49.99
NEW Battery Hold Down (Original Battery Size ONLY)
$24.99
NEW Steering Rag Joint
$24.99
NEW Steering Shaft Joint (Samurai)
$44.99
Lower Alternator Bracket 1.3L
$59.99
Upper Alternator Bracket 1.3L
$44.99
Fan WITH Clutch
Fan WITH Clutch
Fan WITH Clutch
$89.99
NEW Bolt Assortment Kit
$29.99
Fan
Fan
Fan
$54.99
NEW Washer Tube
NEW Washer Tube
NEW Washer Tube
$12.99
Engine/Transmission Plate
$54.99
Valve cover
Valve cover
Valve cover
$79.99
NEW Oil Pick Up Tube 1.3L
$64.99
Stock Carb Part -EGR vacuum diaphragm
$44.99
NEW Coolant Temperature Switch
$19.99
Stock Carb Part - Mixing valve
$39.99
Black VSV for 1.3L carb engine
$39.99
VSV for EGR 1.3L Carb models
$44.99
Stock Carb part - Secondary switch
$39.99
Cam sprocket 1.3L
Cam sprocket 1.3L
Out of stock
Cam sprocket 1.3L
$99.99
NEW Woodruff Key (crankshaft key)
$14.99
NEW Oil Pressure Switch
$24.99
NEW Crank Gear 1.3L
NEW Crank Gear 1.3L
NEW Crank Gear 1.3L
$74.99
Crank pulley 1.3L
Crank pulley 1.3L
Crank pulley 1.3L
$84.99
Crank Pulley 1.3L  (double row)
$129.99
Fan Pulley 1.3L (V-Belt)
$44.99
Cylinder head cam gear backing plate
$44.99
OEM Ignition Coil
OEM Ignition Coil
OEM Ignition Coil
$49.99
EGR valve 8 VALVE ENGINE *Refurbished*
Out of stock
$114.99
Steering shaft
Steering shaft
Steering shaft
$74.99
Piston rod nuts
Piston rod nuts
Piston rod nuts
$22.99
1.3L Piston + Connecting Rod
$69.99
AC Compressor Hose
AC Compressor Hose
AC Compressor Hose
$99.99
NEW 1.3L EFI Throttle Position Sensor 1990-95
$99.99
EFI Throttle Body Fuel Line 8V
$69.99
Carburetor Thermo Plate
$29.99
Oil pan bolts
Oil pan bolts
Oil pan bolts
$29.99
Flywheel bolts
Flywheel bolts
Flywheel bolts
$29.99
Exhaust manifold springs
$19.99
Engine Oil Dipstick 1.3L
Out of stock
$39.99
1 - 60 of 64 items
Prev
12
Next
