Store
Get directions
Engine + Under Hood Parts
Store
CLICK HERE For Sidekick & Geo Tracker Parts
Parts found under the hood and for the 1.6L engine
Sort by
We recommend
Bestsellers
Newest arrivals
Price: Low to High
Price: High to Low
Name: A to Z
Name: Z to A
Filters
Clear all
Filters
Clear all
Show items
Show items
NEW Distributor Plug 1991-95
Buy Now
$34.99
NEW Fuel Injector 1.6L 8V
Out of stock
$124.99
NEW 16V Intake tube
Buy Now
NEW 16V Intake tube
$64.99
NEW 8V Rocker Shaft Screws
Buy Now
$24.99
NEW Distributor O-Ring
Buy Now
$10.99
NEW 1.6L Harmonic Balancer (Crank Pulley)
Buy Now
$144.99
NEW Woodruff Key (crankshaft key)
Buy Now
$14.99
NEW Crank Gear Bolt 1.6L Engine
Buy Now
$29.99
NEW OEM Crank Gear 16V (96-98)
Out of stock
$129.99
Crank gear 16v 92-95
Out of stock
$64.99
NEW Timing Cover 1.6L 8 VALVE
Buy Now
$99.99
NEW Battery hold down (oversized)
Buy Now
$36.99
NEW Washer Tank Pump
Buy Now
$24.99
NEW Coolant Temperature Switch
Buy Now
$19.99
NEW Oil Pressure Switch
Buy Now
$24.99
NEW Bolt Assortment Kit
Buy Now
$29.99
NEW Starter Bolts
Buy Now
NEW Starter Bolts
$17.99
89-90 Aluminum Intake Tube
Buy Now
$74.99
NEW 1.6L 8V Throttle Position Sensor 1991-95
Buy Now
$99.99
NEW Oil Pan 1.6L 89-95
Buy Now
$124.99
IAC Idle Air Control Valve 16V (92-98)
Out of stock
$124.99
16V fuel rail
Buy Now
16V fuel rail
$114.99
NEW 16V rubber intake tube (Short tube)
Buy Now
$34.99
16V aluminum intake tube
Out of stock
$84.99
8V intake tube cap
Buy Now
8V intake tube cap
$24.99
1.6L oil pick up tube
Buy Now
$99.99
Washer fluid tank
Buy Now
Washer fluid tank
$64.99
16V VSV
Buy Now
16V VSV
$39.99
EGR Solenoid Valve VSV (1.6L 16valve)
Out of stock
$74.99
1.6L fuse block 96-98
Buy Now
$84.99
MAP sensor 8v 91-95
Out of stock
MAP sensor 8v 91-95
$74.99
MAP Sensor 1989-90
Out of stock
MAP Sensor 1989-90
$139.99
MAP sensor 16V
Out of stock
MAP sensor 16V
$84.99
Flywheel bolts
Buy Now
Flywheel bolts
$29.99
Oil pan bolts
Buy Now
Oil pan bolts
$29.99
Aluminum intake tube 91-95 8V READ DETAILS
Buy Now
$74.99
Connecting Rod 1.6L
Buy Now
Connecting Rod 1.6L
$59.99
16V Timing tensioner & spring
Buy Now
$44.99
EGR Valve 16 VALVE ENGINE *Refurbished*
Out of stock
$99.99
EGR valve 8 VALVE ENGINE *Refurbished*
Out of stock
$114.99
Hood prop rod
Buy Now
Hood prop rod
$49.99
16v Coolant tank
Buy Now
16v Coolant tank
$39.99
NEW 89-91 Coolant tank
Buy Now
$34.99
Crank gear 1.6L 8 valve
Out of stock
$79.99
Piston rod nuts
Buy Now
Piston rod nuts
$22.99
Engine-Transmission Plate
Buy Now
$44.99
Fan pulley 16V
Buy Now
Fan pulley 16V
$44.99
Fan Pulley 1.6 8V
Buy Now
Fan Pulley 1.6 8V
$64.99
Fan
Buy Now
Fan
$54.99
Fan WITH Clutch
Buy Now
Fan WITH Clutch
$89.99
8v Upper Alternator Bracket
Buy Now
$29.99
8V Lower Alternator Bracket
Buy Now
$49.99
16V Upper alternator bracket
Buy Now
$49.99
16V Lower alternator bracket
Out of stock
$54.99
16V Distributor housing + NEW O-Ring
Buy Now
$59.99
8V Distributor housing + NEW O-ring
Buy Now
$84.99
1.6L 8v Distributor 1991-95
Buy Now
$124.99
1.6L 3 PIN Distributor 1992-95
Out of stock
$124.99
1996-98 Distributor 1.6L 16V
Out of stock
$129.99
1.6L 8 VALVE Timing Tension Bracket
Buy Now
$44.99
1 - 60 of 90 items
Prev
Next
